That button is a good idea as its easy to see, but the sign should do the same thing with your manual buttons you already have... They are in the bay by the exit door right? It doesn't matter how many open buttons you wire in - if the stop circuit is open, nothing will work. And if a down button is latched on by either the button or the car wash, then it depends on the logic of the "brain" (if there is one) as to whether it will process the 'up' request. But it most likely will ignore the 'up' request if its the controller I think it is.
