David rooke
Hey guys, I have recently started working at a carwash site with a Razor installed with an air weep system.
And im trying to get my head around it.
The heat setting works as I expect it should, in bay temp reads 38 and heat is set to 36, so the heat is off. Good.
The weep is set to 36 and the in bay temp reads 38, but the weep is on. If I set the weep temp to say 50. It turns off. From my understanding at 50 the weep should be on at a bay temp of 50 or lower, which the bay is.
This has something to do with the right/wrong type of solenoid?
What temp should I set to ensure that at 36 degrees the weep will activate.
