Martins
Hey all back again for some more info!
First and foremost after getting my foam working again i noticed i wasn't getting any product to the bays... could hear the air coming through the brush but no product... so i went back to the ER and found my Foam brush pump not... pumping. So as my many years of mechanical expertise goes, i kicked the pump and wouldnt ya know.. started pumping again haha. So with that said its sort of accelerating my revamp of the ER and thinking about picking up the airlogic pre plumbed system since a replacement pump is about half of the cost anyway. My question is I'm looking for how some of you have your foam brush systems set up. (Diagrams/parts)
Currently half my bays have low pressure hose running from the solenoids And some are running poly tubing (which is what im thinking about re running all my bays this way.) but as previously stated half my bays also have foamers and others dont. (Thanks for the links on the foamers) But i cant seem to find the manifold blocks on kleenrite that connect the air line and product lines before they go to the bays.
my other question is those of you using the tankless injection options how do you like them. Pros/cons. Trying to make a decision quickly as i don't want my brushes down too long.
and laslty i know some of you have your trough heat tape hooked up to your weepmizers. What tape and whats needed to make this connection? Not having a weep on my foam id life to make this system work with the weep rather then running extension cords and such up there.
Thanks again!
Thanks again!
