94050 Jim Colman shampoo vac - getting old solution out
Back 40
Have a Jim Coleman 94050 shampoo vac that has been used just as a vac for at least five years, well I got everything repaired and working on the shampoo side, but I have no idea what the mixture of the solution that's been in it is. What's the easiest way to get it out so that I can mix a fresh batch in it?
Also does everyone that has one of these only use Jim Coleman shampoo solution in thiers?
Back 40
The valve in bottom left of cabinet that looks like it's a site gauge?
Back 40
Do you have to use Jim Coleman shampoo or has someone found a better alternative?
I use warsaw 32 to 1 carpet shampoo from their industrial division. I put 20 ounces of concentrate in 5 gallons. it cost less than $2 per tank fill
I assume Fragramatics concentrate will work - I use it mainly because I like how it smells.
vinh
I use Kleen-rite summer concentrate. Mix 1 gallon to 5 gallon water. Cost $41 for a 5 gallon concentrate. What is the name of the warsaw product? Your $2 per 5 gallons is cheaper than my $8 per 5 gallon. Does the warsaw have a fragrance to it?
Lexington, Ky.
I use the Kleen Rite winter concentrate in the winter, but in the summer I just use the Pro-Force shampoo from sams. I put a couple cup fulls per fill up and it foams great.
