Bubbles Galore
I have a meterbox from Etowah Valley that is giving me some problems.
Problem: When the rotary knob is placed on spot free, the function itself works fine, but the voice says 'STOP'. This isn't so much of an urgent issue if you are paying cash, but a much larger issue if you are using our cc count up method. To see what was really happening, I ran 2 tests.
Test 1: I placed the rotary knob on tire cleaner and swiped my card. I used the functions for the minimum and then moved the knob to spot free (making sure to bypass the stop button). At that point, the meterbox ended my transaction.
Test 2: I placed the rotary knob on tire cleaner and swiped my card. I used the functions for the minimum and then moved the knob to stop. At that point, the meterbox ended my transaction.
I checked the wiring in the box and everything appears to be good. I need some advice on what my next step should be. My other 7 bays have the push button type setup, so I am kind of at a loss if I need to investigate something on the rotary knob. Most people that use my cc box, use the spot free, I can only imagine how frustrating that is for my customers, since it is driving me up a wall.
Thanks for the help!
