Thanks for the reply,we wash&clean out the pit weekley so no dirt or sand build up is there. and i am running a 3'6' spaceing,the chain still looks good but the rollers are getting sloppy with play.That is like asking what does a hen weigh. Pit and dirt conditions will determine life in most cases. If you have a dirty pit, I have seen rollers and chain get eaten up in a year to year and a half. If your pit is clean, there should be no problem getting 3 years or so out of the chain - maybe rollers as well. Also, you are averaging 54k cars per year. If you are express with gates, you are probably 3'6" spacing or so instaed of 7"6". That means you have greater weight of additional rollers making the trip down the conveyor and they do wear to some extent even with no load. Most manned tunnels with that type of volume can get away with 7'6" spacing. Long story short, more rollers means more wear. keep the pit clean always. Sounds like you are ok with the wear. You can also flip the chain and rotate pins for more wear.
" flip the chain" that's pretty funny....no dont flip the chain or try and replace bushings in the rollers.
Earl,
I believe the rollers are from Sonny's because of the X458 chain.The chain and rollers only come in 3'6" spacing, and the rollers dont have bushings.The chain is pretty heavy duty. This is why it is only available in the shorter spacing, too heavy to support a 7'2" spacing.
I don't think that bonzai is having a problem with the rollers, he was simply asking about the expected life.I use this chain and roller setup at my locations and I think I can give a pretty good indication of the life expectancy....just my opinion sorry if I offended
