1/4" solenoid
Bill Manke
Reno Nv
Looking for a 1/4" solenoid that can stand up to corrosive acid, Have tried parker stainless steel but still having problems. Any sugestions? Thanks Bill.
robtl
central Ky
central Ky
What grade stainless is the Parker valve you are useing you may have to go to a higher grade stainless or a different type valve .
What is failing on the Parker, the seat, the needle, the body, the threads??
Bill Manke
Reno Nv
Not sure what grade it is. Came on markVII. seat is pitting from chemical.
robtl
central Ky
central Ky
Gabriel
I think I would try a different chemical or at least cut back on acid. You can clean without high acid that damages everything including your automatic, walls, floors tubing, equipment and hopefully not customer cars.
