Petit or Oasis distributor
You are so angry and bitter. It is obvious to everyone but you how abrasive and bias you are. You don't like Petit ok dude grow up and move on. You have zero data to comment on a Petit's reliability and when people that do have data comment you call them liars. I know alot of Petit customers that get 100,000 cars plus out of hoses and sensors.
I would like everyone that reads this comment and your comment to go to page 1 of this thread start over + read comments and evaluate who is the angry and bitter person in denial.
BTW your last and only 15 posts have been against me and pro petit. Talk about bias lol
In your climate I would defiantly go with a Oasis since their machine has a heated system integrated with it. They do not rely on just doors to keep it from freezing like a petit does. Also it is way FASTER then a Petit. Give Oasis a call they will take care of you.
oasis is not, nor will ever be faster than a petit, thats petits selling point, ive timed our 8 pass on our petit, 3:40 for an 8 pass wash.....
Just cause it’s there selling point does not mean it’s true. Why don’t you do a little research buddy. A typhoon can do 16 passes in three minutes. So yes it’s twice as fast.
For me a petit it is over priced. Yes it is fast but those close to me just don't clean as well as the machines they replaced. One had an old DS that was on it last leg but it cleared my Jeep and my Van much better especially the windshield.
everybody in the South needs DWELL time. While getting dwell time, you also need some speed. But not sure the 2 are compatible. ha Oasis seems so fast, you may need to have too much idle/dwell time, & customers think somethin ain't working?
My 6 pass Petit is 3:50. That is pretty dang fast!
My 7 pass Razor Edge is 4:40 7& that is pretty fast.
If I can get an Oasis to have 90 secs of PS on the car, allowing it to work, then layer 3x Foam, then HP rinse, then Ceramic & finish w/ SFR & do that @ 3:00... then that is a game changer! I also like to apply TC/WC w/ a CTA as they enter, just to add more PS & more dwell. I think putting that on a Dry car (& not having undercarriage) works best down here as well...
Dwell is an absolute must with the typhoon or it will not clean. It is too fast. Typically I set up top washes like this:
PS1 Pass
Dwell Pass
PS2 Pass
Dwell Pass with UB
Rocker Blaster Pass
HP Pass
Triple Foam Pass
HP Pass
Rain Bar Chem Pass
HP Pass
Rain X Pass
Med Pressure HP Pass
HP Wax Pass
Spot free Pass
All that in three minutes. Basic washes are around 1 30 sec. You can layer the chemical on and do a top washes in 1 30 but that’s not the right way to do it and customers will probably feel like they are getting ripped off.
PS1 Pass
Dwell Pass
PS2 Pass
Dwell Pass with UB
Rocker Blaster Pass
HP Pass
Triple Foam Pass
HP Pass
Rain Bar Chem Pass
HP Pass
Rain X Pass
HP Wax Pass
Spot free Pass
1. Only thing I see I may do is: switch Rocker Blaster with the TRiple Foam Pass & remove 1 HP pass. That would add 15 more secs dwell, by layering the 3 foam.
2. ALso, what exactly is your Rain Bar Chem pass used for? I was talking about in a very affluent area, where they want to have Ceramic for sure.
3. Have you seen a Typhoon that has a Ceramic Lava curtain, with the wash's logo shining through it?
So you want to keep it an even number of passes so the machine always returns home on SF.
What you could do if you want to speed things up is apply the TF while the rockers are on. Then you can also delete a HP pass. That will save about 30sec. Your going to have 60 sec of dwell time which is more than sufficient.
Rain bar is mostly used for either a carnuba or ceramic wax.
I don’t recommend the lava curtain. Uses 3-4 times more chemical then a rain bar and no matter how perfect you get it, it always changes. I have seen the washes that have the logo on the curtain but only tunnels. You wouldn’t be able to do that with a iba IMO since the machine is constantly moving.
Petit has a built in weeping for cold climates. I'm in Anchorage, Ak and have (4) of the Petit 360i's installed. never had an issue.
Yes but you’re still relying on your doors. The weeps not going to help your rails from freezing if a door gets stuck open.
You wouldn't have any issues with running Petits in your area. I operate (4) of the 360i's in Anchorage, Ak.. They have a built-in weeping system. Replaced our WW2.0's with the Petits and absolutely love them. 4 min 38 second (8) pass wash time on my ford crew cab truck. We are catching every inch of the vehicles surface area. The SUV's love the wash they receive. Good luck with your research!!!
I must be really lucky, in 20 years I've had icing problems in 1 bay with my Colemans and no issues with my Petits yet. not saying it won't happen but I'm definitely in a colder climate than Tacoma, Washington.
The reason you didn't have icing problems with your Colemans is because they have a machine and rail heat system circulating antifreeze.
As long as your doors work you wont have a problem with the petits. If just one door get hit or stops working thats it your done within 20 minutes.
The weep is pretty comical considering if your doors work then you dont need it but if a door doesn't then your machine will freeze but your wands wont. Not sure how that is any benefit at all whatsoever. That machine can not run with just one door and a weep system. Let alone no doors at all. The rails and trolleys will freeze after a few washes. Like I said that machine relies on doors to run in a cold climate state.
Customers will always love any new machine. They dont know the difference between a petit or a wash world. Good luck to you sir and keep spare door parts on hand (VFD, photo eyes, and motors). Especially being in Alaska if someone completely takes out one of your doors then it's weeks if not more for a new one. You'll have to tarp off the bay and keep a torpedo heater or bay heater running constantly to avoid severe damage to the machine. Keep carrying that lucky rabbit foot around with you.
This is why washes have radiant heaters in cold climates
There is always going to be a potential point of failure that could cause a machine to freeze but I'm not losing sleep over it.
Yes radiant heat is a must. I have radiant heat, machine/rail heat, floor heat, and heat tape on door tracks. All of it is just insurance for not IF but when something happens. Unfortunately though without doors working radiant heat will do nothing.
I’ll attach a pic that shows the inside of a bay door with all the heat mentioned above working. The ice will still build up on a touchless.
