Mosmatic Comfort Hose
OK, here ya go Nick-same gun and bay for changeover and pressure tests to keep things consistent. Bottom line, essentially the same performance as the comfort hose. The 1/4" WB does feel slightly clunkier than then mosmatic, but still much better than a 3/8"
I'd say the 1/4" is worth a shot, especially for those concerned with durability or theft. I'm gonna get my wife to give me an assessment.
KR part # HA124WBL0606 12' ft 1/4" single braid hose with 3/8" MPEBOMP90089 mosmatic comfort hose 3500mm
length12'11.5'
weight2.16 lbs.98 lbs
low pressure changeover time10.5 seconds10.5 seconds
pressure at nozzle940psi935 psi
cost$26.81 + 2.14 for each hose guard$37.62
length12'11.5'
What do you use to measure the PSI at the tip in the bay?
length12'11.5'
Thank you Greg. Great assessment. Let us know what the wife thinks. I think the 1/4" route is going to be better for my situation. I won't have to worry about someone cutting it and even if it's rare I won't have to worry about it kinking and stopping the weep in the winter. I did order a mosmatic hose just to try though. Wish they came in more sizes. I use 15' and 17' hoses in my bays and they come in 14' and 16'. I suppose if I like them I can make my 1 ft swivel saver hose a foot longer to make up for the difference. Appreciate the feedback sir.
I have a trigger gun and barrel. At the end I have a 1/8" street tee, then a 1/8" to 1/4" adapter that I have a pressure gauge on. I have a 2506 nozzle on the end. I use that to get close to 1000 psi at the bay with the trigger pulled. This ensures bay to bay consistency.
