I am in need of a water heater for my wash. I have a lochenvar knight boiler that you can buy a hot water tank option for, or maybe I need a tankless water heater? What type should I get? Which would be more efficient? I am just looking to heat presoak and maybe wax.
Sparkey, a little more information would be helpful. Are you using your boiler for floor heat only? Are you heating any water now? We use both a on demand type water heaters or a 199K BTU tank type heaters, depending on which car wash.
I am sorry, but if you are in a climate that has issues with freezing weather the last place I want to consult is an operation in the desert., you can consult with the most reliable support water heater dubai .
The only function at my car wash that used Hot water was the high pressure soap function. After watching customers use the high pressure soap just long enough for the water to get warm, not hot before they switch to another function. So we turned off the on demand hot water heaters, funny thing happened, not one customer complaint and business has been the excellent. So why have hot water?
I would think everyone's cold water would be around the same temp being it comes from the ground. The tanks in the equipment room would be the only variable and its pretty safe to say everyone keeps their equipment room temperature above freezing.How icy cold the inlet tap water from the specific car wash's location might be a consideration.
No, incoming water temperature varies greatly by geography. I was recently inquiring about one for my home and the plumbers comment was not a good idea with Lake Michigan water. Thinking he was referring to hardness I said Lake Michigan has great water. He then explained and I realized he was talking about these heaters working on the "Rise" . Lake Michigan water is cold in the inter. Sometimes water lines even freeze and break underground. Still, I have a demand heater at a tunnel - recently replaced a Tank type and I am happy.I would think everyone's cold water would be around the same temp being it comes from the ground. The tanks in the equipment room would be the only variable and its pretty safe to say everyone keeps their equipment room temperature above freezing.
