Is the flow weak when the softener is in service, or does it stop completely?duk said:I have Alamo softener that it cuts city water to all equipment
A "bypass" valve is a valve that allows you to circumvent or bypass the water softener(s). I'm not sure this is what you are talking about. You'd normally ONLY use it during troubleshooting...or maybe during a time when the softeners break and you'd need to keep water going to the wash.
One danger, you do NOT want hard water going to your RO. The membranes will get fouled and probably become damaged. If you do "bypass" the softener(s), make sure you turn your RO off.
