Vacuum Vandalism - How to fix lock?
Hello, we had some vandalism this weekend on our vacuum. I am curious how to go about repairing this? Is this something where I can buy new Modeco locks and install them, or do you think the drill has done more damage than visible? I haven't tried to put the key in the lock yet until I got some advice on the forum. Thanks in advance!
Order new plug locks.
You should be able to use the key if you clear the opening to the keyway. The tumblers aren't that close to the front of the plug. i'd try using a curved pick to pull out the pits of brass. You may need to use another really sharp drill bit to clean the keyway, just enough to clear out the damaged area. I think I'd use a larger bit, 1/2" or larger, not a small one. Try not to damage the look housing. the housings are available and easy to get. Don't make yourself overthink it.
@Randy, how long would it take you to get those 2 locks out? 5-10 minutes?
It'd take me about 5 minutes out an the door open.
Before you do anything you want to order a couple more Medeco plug locks. You can get them from Kleen-rite https://www.kleen-ritecorp.com/p-963-medeco-plug-lock-and-key.aspx
Or you can go on Amazon and search for a Medeco Plug lock, I just checked and they are $29.97. you want to get them keyed alike. Before you try to drill them out contact me and I'll help you.
You may also want to figure a way to put hockey puck lock over the Medeco lock. It will slow them down and they sometimes get discouraged if they remove one lock and then find another - Randy's method i scary good.
