Unitec Wash Select II overheating?
Anyone had this issue? My coinco validator will not accept bills. It will however take credit cards. It appears there is no power. I have contacted Changemaker and even sent the validator to them who indicated there is no issue with it. They said if the red light is not constantly lit, then it is not getting power. If I plug it in later it will work which may indicates that it may be a "heat" issue. Will the Unitec shut down power to the validator if it gets too hot? I even put a new cooling fan in the Unitec to see if it would help but to no avail. Before I completely replace the validator I want to make sure nothing is wrong with the Unitec. Thank you for the help.
Please contact Unitec's Technical Support department at your earliest convenience - they will be happy to help you diagnose your problem. They can be reached at 443-561-1200.
Jennifer Ward
Unitec Electronics
