I've had 3 motor vacs from the git-go and charge more than my competitors do. The "turbo" option is just a gimmick, set them up with three and charge accordingly. I've yet to have a customer start a sentence with "If your vacs only had less suction".
Consider using the Domel vac motors - they only cost about $10 each more than cheapo ones and have more lift and more airflow - only problem is they're about 1/4" taller and won't fit all vacs.
Nope, the regular Domel 492 motor. It's a little higher than regular motors at 9.7 amps, but it's within the specs of 12 ga wire and a 20 amp breaker with two motors.
I agree 1000%. I am the only SS wash that has 3 motors in ALL my vacs. I've done it that way for 22 years. Every customer coments on how MUCH more powerful my vacs are to the wash down the street. I charge more for less time, never had a customer NOT compliment me on the vacs. Another great advantage is IF one motor goes bad the vac still performs half way decent until the vac can be repaired.I've had 3 motor vacs from the git-go and charge more than my competitors do. The "turbo" option is just a gimmick, set them up with three and charge accordingly. I've yet to have a customer start a sentence with "If your vacs only had less suction".
JE Adams "single use" 3/motor vac model 9253. Before that I had Monorail G-2 vacs w/ 3 motors. The JE Adams is even more powerful than the Monorail. The bag setup inside was different between the two. I am not saying it is a good thing when 1 of the 3 motors goes down, but if you only have 2 motors to begin with, you're out of business when one is out of service. The vacuum still picks up lose dirt and debris with 2 motors, it just gives me time to find the problem and fix it accordingly.What brand of Vac are you running? If a motor goes bad you lose you now have 2 running and ALMOST 50% of that suction will go thru the opening where the bad moor is.
I'm sure a 3-motor vac with a motor out would still work a lot better than a 2-motor vac with a motor out.
That's exactly what Fragramatics does on their turbo vacs. I couldn't believe how cheesy it looked when I first saw one, but it works.I.B. Washincars said:Put a check valve under each motor and now we've got something.
