So with the recent discussion on chemicals and fighting road film and eyebrows, I wanted to show how we have been able to essentially eliminate both in our touchless. A year or so ago I was talking with one of the chemical manufacturer's tech about dwell time. He told me that in regards to IBAs, the longer the better. So I have adjusted my packages to allow the maximum amount of dwell and the results have been remarkable! Our Oasis XP is able to provide a top wash with ceramic, tire cleaner, rocker/wheel blasters and undercarriage at 4min with a 2min total dwell time. High PH only with a PH of about 13 and Low PH triple foam with TF at a thickness that allows it to slowly move across the glass. While my XP is set up for both high & low PH, I've not had the need for low and it would just add time to the wash.
I hope this will be of some help to others in the fight to get better results from their touchless systems. However, I am not familiar with other touchless systems and curious if this can be easily duplicated on touchless machines from other manufacturers? My only other touchless was a Rainmaker and it would not have been able to duplicate this as all chemicals came from the same nozzles.
