Timer Swap
Twelch2300
Hey I currently have IDX Gt-200 installed in my bays and they work fine, but I was considering swapping them out to the Dixmor 7 or 8's to gain the ability to count up and set the number of seconds per coin instead of having to do coins to start and time and letting that divide up the time for each additional quarter added. Anyone know the difference between the dixmor 7 and 8 and how hard the timer swap is?
The GT200 will count up in seconds when it sees power on the white wire time hot. You just have to enable credit. Depending on your credit card system you may need to add a relay to handle the load. When a customer cancels / stops the card session the GT200 will start the scrolling message.
White #6?
On the GT200 the White wire pin #6 is timed Hot. If the White wire sees 24VAC before a coin pulse the display starts to count up . It will stay in the count up mode as long as power is applied. The Credit Card mode must be enabled with the programmer /RC800 to do count up.
