Timer buzz
wolfe
PDQ Wolfe
Have self serve touch tron panel, Ginsan equipment, gs200 timer 4 years old. When money is put in the timer buzzes and no function switch will work, timer light is on and flickers slightly. Bad timer?? Reset with mode button and it clears, put money in it buzzes same thing..anybody??
First unplug power to validator and try it. Check plugs inside timer. Does the timer count the money and then switch to show the time? You may want to unplug the buttons and then hooh up one at a time to see if you have a bad button. With out the door on a test bench it could be hard to find the problem, could be the timer or could be the board.
Timer does rack correct time, plugs are plugged in timer, will check validator and board out, thanks for the tips..
wolfe
Finally found trouble,a relay had failed on the board, sent panel to Ginsan in G Rapids for repair, works like new. Sometimes you need a little help. Thanks for the input.
