Stuck nylon nut
Heating it up and melting the nylon/plastic insert won't work. It's a steel locking nut with a nylon/plastic insert.
It will work, the steel threads are stripped, the nylon is what's holding on. It has to be very hot to melt the nylon which could damage anything that is too close.
Sorry guys,
I cleaned the old coin acceptor and it started working much better so I wasn't in a huge rush to get it fixed. I did get the nut off. I took a Dremel with a cutting bit and cut it off. I did damage the threads slightly towards the bottom of the stud but I just got a small spacer and slid over the stud and tighten the nut down on top of it.
