GoBuckeyes
Self-Serve and Automatics
I'm also having problems with a StaRite booster pump but didnt want to hijack Buzzie's thread.
I'm using a StaRite HP7E to run water through an injector system for my automatic. At one location, my pumps working pressure has dropped from 160 psi through my injectors to 120psi. I have looked into everything including water feed pressure, regulator, and a possible solenoid not fully closing. I have determined it to simply be the pump. While it runs smoothly and has no abnormal sounds, it will only produce 160psi when deadheaded. This model is rated at 6 gpm @ 195 psi.
Can this pump be rebuilt at a reasonable cost, and if so, how do they last?
If it cannot, will this pump catastrophically fail or just gradually lose pressure boosting ability?
