crewchief97
The insert in the spray tip that looks like a figure eight, what does it do? Do you guys leave them in or take them out? Thanks
While we are on the subject of spray tips, what size is everybody using currently I am using 1508 customers seem to know the difference with a wider spray pattern not so much pressure but great coverage.
Do all water conditions dictate that nozzles be changed. I never change mine. (Except when I replace a Gun.)
We use a 1505 tip and run the pump at 1500 psi, change the nozzles out every 9 months.
