slugbuster 2
ANDYS
i have slugbuster 2 in my coin wash last few days the coin have been getting
stuck in the coin mech i sprayed wd40 in them same proplem
what should i do to solve this problem :confused:
The first thing you can do is toss the WD-40 in the garbage.
Remove the coin acceptor and install your spare coin acceptor then send the bad one into Parker Engineering and have it rebuilt. Have it made into the EZ model, it’ll come back with a door on the side that you can open to clear a coin jam.
Clean the mechanism with rubbing alcohol and q-tips. Throw away the wd-40, it will gum it up. Strip the oil out and clean the mechanism. Make sure that it closes correctly.
