Ryko 2001 OHD gone insane
I assume your OHD is running correctly again?
Yes, thank you.
All the ultrasonics were weak. After replacing both side sensors, and two on the gantry, it started working, and, solved a problem we have had since the unit was installed almost 7 years ago...
I'm glad your machine is working correctly again ...but all the ultrasonics weak I have a hard time believing...sounds like they changed them all and hoped for the best.
A lot of Ryko ultrasonic problems are often caused by the signals bouncing off of unusual surface areas and not being read by the opposite ultrosonic. This can often be cured without replacing ultrasonics at all.
