From the ingersoll rand website regarding the pup:
A Point-of-Use Provider (PUP) is a 3-in-1 solution for the bottom of a compressed air drop.
In one compact unit, the PUP is a filter, automatic drain, and manifold for multiple
distribution. PUP incorporates a high efficiency 1-micron coalescing filter, which will
remove solid particles, moisture, and oil contamination leaving the air clean and your
system protected. PUP’s unique design provides the solution for condensate removal and
multiple outlet connections all in one compact unit. From a 1" female top entry connection,
up to four outlet connections can be made to PUP. Two 1/2" ports and two 3/8" ports are
positioned around the head of the unit allowing for any piping configuration.
What I can tell you, is that the
flo-jet failures have stopped with this unit installed just before the pumps.
