R rshiggaon Active member Mar 2, 2023 #1 Hello All: Where can I find this RO regulator, need to order a new one. The one marked in RED. Thank you in advance. Attachments RO-Regulator.png 432.3 KB · Views: 24
MEP001 Well-known member Mar 2, 2023 #2 I'm not sure if this is exactly what they came with, but it should work and mount the same. You'll have to check and see if the ports match. https://www.kleen-ritecorp.com/p-3205-spraying-systems-1-2-8460-diaphragm-pressure-regulating-valve.aspx
