Rinse Problem & Others
zepher
When I switch to rinse it takes a while to build up the full amount of pressure (not sure what's wrong or why it's causing this) and the second problem is that the soap takes a while for it to start coming out when on the soap cycle. I'm a newbie to this line of business.
The high pressure delay could be caused by a faulty check valve on the high pressure line or from the water tank feed. If air is able to bleed into the pump somehow, it may temporarily lose its prime. Especilly when sitting for a length of time.
Soap can take some time to arrive in the bay depending on how far the pump is from the bay (length of hose). You might not be able to do anything about this. How long is it taking?
