Post some pics. Do you have block walls? Ive never came across a block wall bay that was so bad they had to do a leg kit.In the process of getting a new Razor. My walls are a little suspect in a few places so I’m opting for a frame. I understand stainless lasts forever, how long for the powder coated? Like everything this is snowballing on the price.
So what are your walls?I don’t but I have a crack that runs floor to ceiling. You can almost feel it move when you push against it. The guys that came & looked at it didn’t feel comfortable mounting it on it & honestly I don’t either.
Does not look that bad. Get a mason over there. The grout cracks is one thing not big deal. The cracks directly in the center of block at bottom can also be repaired/replaced. A razor prolly does not weigh over 300lbs? and that’s being supported by not one but two walls. Unless the bay is really wide I don’t see a leg kit as a must have.Here is a picture of. Single block thickness, other side is the pump room. When I said feel it move it’s not rocking back & forth. You can beat on it with you fist & there is a quite noticeable change in sound.
