R.O. help
rossallen768
im working on a colman sparkle system am lost. so to start with end caps of membrane cans were leaking a little o i thought it was a good time to change membranes. shut the system down changed out membranes fired it back up and all it will do is reject 100% of the water. im at a loss an have no info on the system
If the caps on your RO membrane housing(s) are leaking - you need to at least lube, or replace the orings on the cap. Changing the membrane won't address the leak.
Russ
