He's already said that the supply tank is running dry. By his description I'm guessing it has an individual holding tank for each pump supplied by a solenoid/float valve combo, like the Futura stack systems from the late 80's/early 90's.JIMT said:I think that you are sucking air into the pump from the soap supply line.
He said there was no water going into the tank. He said when he switched it to rinse the tank started filling. He said there are dual solenoids. The only time I've seen a setup like that is when two solenoids feed a small float and tank for each pump.Rick says:
I have three bay SS that the first pump (first Bay) is running out of hot water. dual solenoid valves for the hot and cold water and I have even removed the screens in the hose to help flow.
The strange thing is that the other 2 bays have never had a problem with the hot water supply.
He does not any thing about a tank going dry. I am not sure what he has.
Jimt
That should certainly work, and since it appears by the description given that there's a float valve in the tank, the water shouldn't even overflow. There just won't be any way to control whether the bay gets hot or cold water.I.B. Washincars said:If he has a solenoid and a float valve he should be able to take the guts out of the solenoid and see if the problem goes away. Of course the float valve will leak all over the floor, but this should narrow his issue down.
I wonder if there's something in your water that eats them up. The Watermasters last at least a year in the SS tank for me; the one in the auto has been replaced once in 7 years.I.B. Washincars said:Since virtually every freaking one made last only a little longer than the time it takes to install it, I thought it was a safe bet to say it would leak.
