Pump Inlet Hose Size for Soap and Wax
wrightwash
I'm to the point in our car wash rebuild that it's time to order plumbing materials and valves.
I'm running Cat 430 pumps, which have a 1/2" inlet. They are gravity fed from a pump that's roughly 20" above the pumps. I was considering going with a 3/4" coupler out of the tank to a 3/4" BV and Y-Strainer, Tee in for soap and wax then 3/4" hose to a 3/4" to 1/2" reducer at the inlet of the pump.
While reading on the forums I noticed some comments that 3/4" hose causes suction issues for the soap and wax mixture. Would it be best to run 1/2" from the tank to the inlet?
Also, for my soap and wax valves, I have a 1" coupler in the tank from which I was going to create a header running to 1/4" KIP Solenoid valves, then 1/4" poly tube to the tee's on the pressure line. Is 1/4" valves the normal for this? Also do I need a metered valve?
Thanks in advance! My background is industrial automation, I'm slowly mending that into the car wash world. We're two months into a 5 bay SS car wash remodel.
We got rid of the problematic tanks, flow valves years ago and went with a direct feed water into the pumps, simple to do if you’re rebuilding everything. 2 - ½” solenoid valves for hot and cold water, a Generant pressure regulator to lower the incoming water pressure, and a DEMA 203C injector for the chemical. We have a ½” PVC manifold that runs behind the pumps to supply chemical to the injector, the chemical supply tank is about 5 feet high. We use 2 - 1/8” Kip valves to supply chemical to the DEMA injector.
I run 1/2" hose to the pumps - whether I use push-lock hose or polybraid, I still use push-lock type hose barb fittings that are almost 1/2" inside so there's no restriction. If you're running hot water for soap and wax but cold on rinse, you need a check valve on the hot water line. It's a good idea to have one even if it's all cold from the same tank to prevent any backflow into the tank. I usually use 1/4" OD tubing to the pumps for soap and wax lines unless there's a long run across a bunch of pump stands, in which case I use 3/8" ID. The solenoids will all have the same orifice which becomes an equal limiter to flow, so you shouldn't need individual adjustments.
Thank you! So you add a check on the feed line before the wax and soap tee?
Good to know! Thank you.
