I had a cat 310 pump finally fail. Luckily I had a brand new one on the shelf. I replaced the pump and while I was at it changed all the fittings, hoses, and the bypass regulator. Got it all done, primed the pump and got it going and noticed the pressure gauge read 1250 psi. I went out to the bay and pulled the gun trigger and could see an obvious increase in force so I tied the trigger in place and went and checked the pressure guage and it still read 1250ps. Turned the bay off repeated and same results so I changed out the gun and went thru it all again with the same results. Any ideas on what might be going on with this? I guess I could have a bad pressure regulator even though it is brand new .... what do you all make of this?
