I am getting a Bridge Warning 153 on my G5 but I cannot find any documentation on this warning.
Any help would be greatly appreciated.
Warning 153 is High Soap Temperature
your soap temp probe reported a high temp.
You should ensure that there is heat transfer compound between the temp probes, (and overloads) and the heater tank case. If it is not there the time delays start increasing and this could happen, and is the most likely cause.
Check he accuracy of the temp probes. (may be failing)
hope this helps.
Regards
Mike
