Part identification help
Looking for help to identify a part that is used to fill the soap in a Coleman assembly.
In the picture is the "float switch" that fills the tank, and splices in the soap. It is akin to the toilet bowl filler at my house.
I believe I need to replace it since the pressure coming out of it is low; however, I cannot find this assembly at my local Kleenrite.
Thanks as always.
That's a hydrominder.
Start by making sure the screen is clean and not clogged up restricting flow.
You will need to shut water supply off before.
I hope this is the repair kit you bought
Is you get the plastic stem reuse the brass stem, they are a better stem. We keep a few of the rubber diaphragms KR#IN665500
Sometimes, the eductor can crack allowing the system to suck air instead of product. Again, just keep a spare or two on hand.
Keep a spare:
Eductor
Stem
Diaphragm
That'll cover most anything......
