Nayax card programming
Walter White
Can
Has anyone programmed non nayax cards into their system? I have some printed clone cards and noticed on the Nayax portal you must put in card number (on the card) and a unique card number(not on card) .Is this automatically generated or do i put same number in both sections?
Hey Walter White!
Take your card to the Nayax reader and attempt to tap. You will get an error because your prepaid cards are not added to your system.
Now go into your back office Operations>Machines now select the machine you tapped the card you want to program on. Go to the Info tab>Last Alerts
You will see an alert labeled "Card does not exist" from when you got the error message. Event data will give your a card decimal number. I believe that is what you need to add the card as a prepaid card.
DavidM
PA
UtahYoutubeGuy has it right.
If you get stuck, there is a Nayax University link in the upper right hand corner of the dashboard that has good information on adding cards.
