Mosmatic comfort hoses
David Rolf
So I bought some new mosmatic comfort hoses to try out for my foam brush hoses. Two of the bays have them. I see a big decrease in the amount of foam being delivered in those bays with these hoses as they are a smaller diameter. Anyone else experience this or are you using them just for high pressure? I don't see they make a larger diameter on the Kleenrite site.
I've been using them for high pressure as well as a low pressure hose and they seem adequate. They will however crimp off when used as a low pressure application. The jury is still out on them as if I want to continue using them for low pressure for me. I like the small size on the shelf, and theoretically you could use the same hose for both applications(but I use different lengths)
I have used them in high pressure situations and the only problem is they will kink and in the winter if they kink the weep water will freeze.
