G gomerpyle Member Monday at 1:17 PM #1 The tri foam on the drivers side is not applying very well. How/where do you make adjustments to try and fine tune the water/soap/air mixture? Thanks Tom
chaz Active member Monday at 3:39 PM #2 Check for leaks, clogged (small) check valves or need for new scrubbing pad stuff in tubes first foam or maybe clogged holes where product dispenses
