diamond joe
I have a five bay self serve with D&H equipment.There are three low pressure functions on one circut,pre soak,wheel cleaner and wax.Each function has its own low pressure pump and the air is shared by a manifold with solenoid valves. My problem is that the wax function only works properly in one of the five bays, in the other four it spits and seems to run out of chemical sporaticaly. To date I have checked the following;free flow of chem to the pump...pump output is 60psi....checked all solenoid valves on chem and air manifolds...air press is set at 40psi as always...all connections at the sub manifolds in the attic. Im running out of things to check! The only way to get the wax to dispense smoothly is to lower the air press to about 20psi at which point its realy running off the pump alone.
