Leaking solenoid valve.
Hello. One our bays leaking water due to the valve not closing 100% due to wash out. See pic. Can I find just this part or no need to change the whole thing?
You can fix it, but you'll eventually have to replace it. A Dema 473P is 3/8" pipe thread, a Dema 474P is 1/2". They have a stainless seat insert so they won't wash out like that.
If you want to try and fix it, get a 1/4" bolt, nut, and fender washer, sandwich some emery cloth under the bolt head with the nut holding the washer tight, chuck it into a drill and polish it smooth. You'll probably have to change the piece of emery cloth several times.
