Laserwash 4000 Low Pressure Soap
if your manifold tree is not close to the arch it will take some time to get there. If its close and it still takes too long you may have bad checkvalves.
I agree with pgrzes has this always been a issue or just started happening your pressure of 200psi is good. If your tree is in the equipment room and your bridge machine is 2-3 bays over it will take a little longer to deliver product. You got some check valves bad somewhere more than likely i would check every one on the tree and check the foam in the tree make sure its good and check all your spray tips make sure there all clean and clear if 2-3 tips are restricted it will cause a delivery issues as well
