Found Brush hose broken
Put on new assembly. Worked for an instant or 2 then watery. Notice compressor not running.
Had a spare. Ran fine on the bench. Removed brass fitting from installed compressor and put on spare. Tested it. Didn't run. Found one of the brass fittings was a check valve - Stuck closed. Sprayed it up with WD 40 - Works. Compressor ran, then it would not re start. Then it ran , then would not re start. Spare had same issue. (Shampoo pump runs fine - continuosly)
Thought maybe it was a bad relay. There are 2 Side by side on the back wall in about the center- swapped them - Same issue. Is there another relay somewhere for the compressor?
