iwash help
Carwashjake
I have an issue with my iwash that I am having difficulty troubleshooting. Everything works at low pressure but I can't get high presssure to come on in any of the bays. I have water in the tank and my water supply going into the tank is good. When high pressure soap is selected in the bay the motor ramps up for just a second and stops. Again I cant figure out what is wrong with it and all 4 of my self serve bays are down as a result.
carwashjake,
Check the voltage on each leg of the 3 phase wiring. You may have a circuit breaker tripped on one leg.
JIMT
