i am having some issues with chemical delivery. i have recently switched chemicals and now i am using too much even with the smallest tip installed. i have S.S. injectors and they are about 1 1/2 years old.(as old as the wash is) ive had to replace o rings at the check ball seat in a couple. i asked a couple of wash techs if a injector that has been eaten away can pull too much chemical. i got a yes and a no answer. if i understand the way they work, it is like a venturi effect that pulls the chemical through the metering tips. and if the venturi part of the injector is made larger,i my mind it should pull less due to less of a venturi effect. if i am missing something here, id love to hear about it. id rather not replace all the injectors to find i have the same issue. Thanks, rookie owner in Ohio.
