S slash007 Well-known member Apr 7, 2023 #1 I need to replace a lock in my Portal and am trying to figure out what size I need. If I for example order a 2" extension lock like in this link: https://www.kleen-ritecorp.com/p-45889-medeco-63w-750-m7-k-threaded-extension-lock-with-key-2.aspx where is the 2" measured from? Is it the whole lock from where the key goes to the end of the stem, or just the threaded part? Thanks.
MEP001 Well-known member Apr 7, 2023 #3 It's measured from the flange that sits flat against the door to the point where the cam rests. It's what they call the "A" length.
