How do I add a buzzer?
RustyD123
I’m new to the SS Car Wash. My timers do not have a buzzer on them. How do I add one? The timer is inside the equipment room and the option selector is in the coin box at the wash bay.
You need a timer with a "last minute" alert. There are GinSan timers that have it built in, so you can either directly replace what you have as long as you have an unused wire to connect the horn in the bay, or you can move the timer to the bay. I'd recommend Dixmor display timers in the bay, which will also give you a display of time remaining and future upgradability to adding a credit card system with count-up.
I’ve been using the Parker 24 volt Grace Timer II on my vacuums for years. I use them with a 24 volt mercury relay to control the motors. https://www.kleen-ritecorp.com/p-34389-parker-engineering-01-0238-0000-grace-timer-ii.aspx Before we had digital timers we used the Grace timer in the coin boxes.
We programmed our PLC dog wash with a grace period that counts down on the large touchscreen display. I think a "grace period" has proven to be worthwhile IMHO. Especially in combination with some kind of display showing the grace time!
Now that y’all have explained things, it looks like I can hook a buzzer between 9 & 2. One wire from 9 to the horn; one wire from 2 to the horn?
