Help with Flojet
I had a power outage last night. Finally got the electric repaired and turned out my compressor stopped working. (wont' turn on automatically). I installed a new compressor and everything was back up, except that my triple foam Flojet won't stop clicking. I tried two others and they do the same thing. If you turn on the triple foam in the bay, it works great. Flojet works as it should and triple foam look good. once function is off, the Flojet goes crazy. What should I be looking for as the issue?
All 3 that I tried. I checked the chemical solenoids and they all seemed fine. Maybe I'll take all of them apart and clean them as nothing else makes sense.
I have ball valves before every solenoid to every function. If i have a flow jet cycling when the function is not active, I close the ball vavles 1st and see if the problem goes away. If it does, i will then open the ball valves back up one at a time until i can locate the bay the gremlin is in then can trouble shoot from there.
might help to see a picture of your setup. Does the flojet have a solenoid on the air, only allowing air when 3x is called for by a bay?
