I note the KR site has a single review - one star.Plastic Chemical Filter w/Check Valve, Gray |General Pump|D40003
Keep particulates and debris out of your chemical system with General Pump's D40003 Chemical Filter with Check Valve, only from Kleen-Rite!www.kleen-ritecorp.com
Who makes the best/reliable foot valves lately, I have been using these as seen in the pictures for years, but recently I have been replacing them more frequently. I like them because I build pail stingers with them for 5/15/30 gallon chemical containers.
View attachment 1059View attachment 1058
50 years here, and I've never heard of one either. I'm thinking it's similar to a "Layover, to catch meddlers."I'll have to go with 2Biz, 38 years in the business I don't know what a "Pail Stinger" is.
I cut the hose length to just reach the bottom and weight the end if necessary.How do you guys keep the line/tube from curling up and not remaining on the bottom of the pail?
I thread the hose through a piece of 3/4 PVC conduit. I make sure the conduit is at least as long as the barrel diameter, so it doesn't lay flat on the bottom. This keeps the hose straight and eliminates the need for weight.How do you guys keep the line/tube from curling up and not remaining on the bottom of the pail?
Same - Just a Piece f 3/4" PVC Pipe.I thread the hose through a piece of 3/4 PVC conduit. I make sure the conduit is at least as long as the barrel diameter, so it doesn't lay flat on the bottom. This keeps the hose straight and eliminates the need for weight.
