Bosborn52
Looking at getting a dryer car... like everyone else.
We currently have this configuraton in 3 of our 4 tunnels.
Only difference is the side dryers are lower on the post.
We have 1 tunnel that is 115' with 15' of drip space and 2 tunnels that are 135' with around 20' of drip space.
Our major problem wash is a new 100' tunnel where there is only 10' of drip space and we have our High Pressure going on pretty close to the end of the wash. We are currently getting bids to build a dryer wall to combat the misting issue.
Our dryer setup there is pretty close to this:
It's a peco tunnel and it seems to move the water alot better than our macneil tunnels.
We use a high ph presoak set at 11.6 - 11.9 ph. We then use a low ph lube foam later in the wash that is set at around 2.7 - 3.0 ph.
Currently using qualchem Q Dry as our drying agent and use their Hydropel as our rain x and foamy polishes.
Looking to see if flash drying is a viable option for us. I understand that we do not currently use alot of blowers in our current setup.
Does anyone have any expeirence with these two:
http://www.sonnysdirect.com/c-112-wet-environment.aspx
http://www.macneilwash.com/equipment-details.php?id=466
Will we see a noticable improvement? I understand there are other ways to get a sure fire dry vehicle, but they cost more and we are not looking at heating our dryers.
We are in the midwest, so this time of year is tough to get a really dry vehicle.
Thank you for your time.
