Drying agents do not work only on the chemical action. They work in combination with multiple factors; pH of soaps, drip/rinse space, RO water, humidity, temp and dryer set up. All of these work in conjunction with each other to produce a dryer car, change one and it will effect the outcome.
The best way to get a dry care is to extend your drip space. You should maximize the drip space (or reduce the conveyor speed if possible) to a min of 16 feet from rinse arch to the first dryer. This allows the "break" of the drying agent to shed the water from the setting arch. Alos be sure that the low pH soaps are used if possible, they will help to set the drying agents. You can't freely change the Humidiy or temp as easily but some big washes do with gas heaters up North that will lower the humitity and increase the temp. Here in Florida, in the Summer early morings are difficult to get cars dry until around 10am.... then the body of the car holds enough heat to react all the way thru the tunnel! In the desart SW I'd imagine it would be the same.... a dry car would be little problem. Conveyor speed and drip space is the big issue in most cases... not the dryer set up.
Look at your layout of the equipment. If you can move the rinse arch of rain curtian (I suggest rain curtians) back 2' and keep a moderate chain speed... you'll get a dryer car than spending $60,000 on a stripper dryer system.
