Dosatron with 511 Hydrominder Setup
termn8tr
Does anyone know what tip should be used in the 511 hydrominder and then what should be set at the dosatron to get 1/2 oz. on a vehicle. Just switched over to JBS Action Dry. Lets say you use a purple tip on the 511 hydrominder, what do you set the dosatron at 1:200 1:128??? in order to get 1/2oz on a car
It all depends on how much water is in your final rinse. For example, a rain arch with drying agent uses a lot more water then a fine misting arch with small nozzles. The only way is to measure with an ounce draw. On busy days your hydrominder might not pull as much water, so your final dilution might be different and if your chain speed changes so will your final dilution.
Dosatrons and Hydrominders as stated above don't give you an amount per vehicle as stated above. Purple on a 51 is rated at 120 to 1. Set the Dosatron for this ratio.
