Hi,
I have 20+ yr old Dilling Harris manual wash bay equipment.
It has worked almost flawlessly for 20+ years, usual wear and tear items etc
I have a weird problem now and am hoping someone else has encountered it and has a solution.
On 2 of my bays (5 bay setup) i have this werd thing where the solenoid coil in the foam brush air supply will overheat/(small ejection of molten plastic) when this happens the most obvious thing is when a customer selects foam brush, the power to the in bay timer manager goes off momentarily and they loose the time they had paid for. Clearly there is a short in the system somewhere that pulls the power down from the bay time manger power supply. The question is where the heck to even look? There is nothing obvious, no wire damage anywhere visible, etc. Replacing the coil on the air solenoid fixes the problem for a few months or so until it happens again.
Surely someone, somewhere has had this happen before.
Thanks in advance.
Andrew, Ballina Carwash. Australia.
Thanks in advance.
