detergent feed pump for ryko voyager
jrecchi
I'm looking for a new detergent feed pump for the ryko voyager. Kleen -rite doesn't carry it. any sources and cost for this unit? I think it's a Blue-White diaphram pump.
It doesn't have to be the exact same pump as the origina. In fact knowing ryko, you will probably save money by using a Flo jet air pump, or an electric. Just amke sure the capacity is close, such as the oz. per minute flow.
Mac, a Blue and White pump is electric!
To use a flow jet would require extra parts just to activate the pump.
Stick with a Blue and white, it is very common, lasts a long time and should not be hard to find. It is either a 170ml or an 80ml depending on the application. Make sure you tranfer the prime switch if the new one does not come with it.
